VAG K + CAN COMMANDER V2. 5
что-то так и не нашел прошивку, пару раз перечитал ветку.... ткните носом. Спасибо!
1.4 китай.rar
Вот опись:
V3.6
Features and Specifications
Diagnostic via CAN and Special functions via K-line.
Covers all electronic control units in vehicles (diagnostic addresses from 0x01 to 0x80). This can allow of user to investigate and diagnosis some new units untouchable for remaining diagnostic tools. Functions are under CAN-TP2.0.
Manual definition of running diagnostic session not like remaining diagnostic tools always standard diagnostic session 0x89. Function is under CAN-TP2.0.
Broadcast diagnostic request disable normal communication, clear DTCs, Logistic (transport) mode,.... Functions are under CAN-TP2.0.
Allows managing of brand new units (and immobilizer units) where is allowed programming of PIN, SKC, BGW, MAC. Functions are under CAN-TP2.0.
Most of popular diagnostic requests identifications, coding, adaptations, DTCs and s.o. Functions are under CAN-TP2.0.
Special function - odometer correction in instrument clusters and EDC15x.
Special function - read Security Access Code/Login WFS.
Special function - read/program immobilizer data.
Special function - read/write EEPROM from instrument cluster/immobilizer. All supported clusters CAN/K.
Special function - VAG MMI TV Activation.
Special function - Read/Write EEPROM of Engine Control Units BOSCH VAG-EDC15x, VAG-ME7.1.1, VAG-Cartronic ME7.8,Porsche.
Special function - Key learning buttons for easy usage (not needed security code). Can do component security authorization.
Special function - Key learning Porsche CAYENNE (not needed security code) K+CAN.
Special function - Custom memory reading from different units like ECUs, EZS-Kessy and s.o..
Special function - Reading flash memories EDC16x, EDC15x, ME7x, MED951, MED751 (with next update will be possible programming of flash memories
Special function - Crash data clear in airbag units
List of vehicles covered from function odometer change via OBDII:
Audi Q7 (CAN)
Audi A2 (K)
Audi A3 (CAN) up to 2007 !!!
Audi A3 VDO/M73 up to 2003 (K)
Audi A4 VDO/M73 (K)
Audi A4 BOSCH - RB4 clusters (CRYPTO eeproms R/W by OBDII)
Audi A6 VDO (K)
Audi A6 (CAN)
Audi Allroud (K) up to 2004
Audi A8 (K) VDO93xx
Audi A8 (CAN) up to 2007 !!!
Audi TT (K)
Seat Alhambra (K)
Seat Altea (CAN)
Seat Arosa (K)
Seat Cordoba after 1999 (K)
Seat Ibiza VDO after 1999 (K)
Seat Leon (K+CAN)
Seat Toledo (K+CAN)
Skoda Octavia (K)
Skoda Octavia II (CAN)
Skoda Superb (K)
Skoda Roomster (K)
Skoda Scout (CAN)
Skoda Fabia (K)
VW Bora (K)
VW Beetle (K)
VW Caddy (CAN)
VW EOS (CAN)
VW Golf4 VDO/Motometer/BOSCH RB
VW Golf5 VDO (CAN)
VW Golf5 VISETEON
VW Crossgolf (CAN)
VW Individual (CAN)
VW Jetta (K+CAN)
VW Passat B5/B6 (K+CAN)
VW Polo VDO/Motometer (K)
VW Sharan (K)
VW T4/T5 VDO (K)
VW Touaran VDO (CAN)
List of vehicles covered from function security access code/login reading via OBDII:
Audi A2
Audi A4 VDO (K)
Audi A4 BOSCH (K) up to 2001
Audi A4 after 2000 - petrol engines >= 1.8
Audi A6 VDO (K)
Audi A6 (CAN) petrol engines
Audi Allroad (K) up to 2004
Audi Allroad (CAN) petrol engines
Audi A8 up to 2001
Audi A8 from 2001 to 2002 2.5TDI
Audi A8 (CAN) 2003+ petrol
Audi TT (K)
Audi Q7 petrol engines
Seat Altea (CAN)
Seat Ibiza (VDO) after 1999 (K)
Seat Leon (K+CAN)
Seat Toledo (K+CAN)
Skoda Octavia
Skoda Superb
Skoda Roomster
Skoda Scout (CAN)
Skoda Fabia
VW Bora
VW Beetle
VW Caddy (CAN)
VW EOS (CAN)
VW Golf5 VDO (CAN)
VW Crossgolf (CAN)
VW Individual (CAN)
VW Jetta (K+CAN)
VW Passat B5 (K) B6(CAN)
VW Polo5
VW Sharan after year 2000
VW T5
VW Phaeton petrol
VW Touareg petrol
PORSCHE Cayenne (CAN/K)
Current version 3.0 covers VW/SEAT/SKODA (CAN) up to September 2006 while AUDI covered up to 2007
Руками и программатором Ауди этих лет делается легко. Можно и через ОБД, но в досе на 98 винде. Ну и всеми командерами она должна читаться и программироваться.
Доброго времени суток!!! А Вы не могли бы пошагово проинструктировать как скрутить пробег на audi a6 2001 года выпуска 2,5tdi при помощи VAG-K+CAN COMMANDER FULL 1.4.Mожно скинуть на мыло sna1968@yandex.ru.С уважением ,Сергей.
всем добрый день у меня есть пару вопросов насчет " VAG K+CAN Commander " может мне кто-нибудь поможет
1- Как можно получить логин что бы привязать ключи и тахо
2- Как можно адоптировать тахо на ауди А6 2000 года 1,9 дизель
3-Kак можно в дампе опредилить км и логин, так как слышал што можно только как
Пардон за дурацкие вопросы: заказывал на eBay VAG K+CAN Commander 2.5, продавец прислал VAG K+CAN Commander 3.6. Заменяет-ли 3.6 версию 2.5? Вообще в чём отличия между ними?
  • 5 недель спустя...
старые кончились пошла новая версия в любом случае лучше
Интересно, а схема версии 3.6 отличается от версии 2.5??? или там идет всево лишь правка прошики PIC контролера???
]Здравствуйте!
Подскажите пожалуйста, купил китайский VAG K+CAN как версию 3.6. В комплекте был диск с программой, ключа не было. Дрова встают, комп шнурок видит, но соединится с Ауди Аллроуд 2002 год по К линии не удаётся. Пробовал разные программы от 1.4. до 3.6., результат одинаковый. Прочитал всю ветку, скачал VAG_K_CAN_Check и он пишет:
Found Vag K+Can interfaces:
VAG K+CAN: 02xx v01.00 : 3, KLline: B1: NOK, B2: NOK,B3: NOK,B4: NOK,B5: NOK,B6: NOK,B7: NOK.
Версию меньше чем 1.4 не встречал, или всё таки когда-то была 01.00?
Подскажите пожалуйста что это за зверь и будет ли он работать с каким-нибудь Vag K +Can по К линии.
Изменено пользователем ium
Здравствуйте! Попался в руки шнурок на нем написано VAG k+CAN, на диске одна программа которая подключается но выводит сообщения в виде набора цифр! Что это?
Уважаемые помогите. Сегодня возился с одометром и ничего не получилось с мафинкой VW CADDY 2006 по CAN линнии когда подсоединяюсь кнопки (мотора и панельки приборов) не активны.
Шнурок 1,4 чайна прога такая же. Шнурок брал на е-бей и перед этим по к-линии свой VW T4 2002 года победил одометр без проблем.
К Caddy соединение проходит, но не могу разобраться как сделать активными кнопки. Заранее благодарен
Я сегодня переписал пробег не такой же CADDY .Выбираеш протокой CAN потом Combi и Open Channel .
vag k+commander 1.4 china with the VWTester.exe size 1467392 bytes and lpk.dll size 44032 is a working cracked version, but should be used in a VM because it has a trojan downloader inside.
What older version of VCDS is working with the 'vag k+commander 1.4 china' cable?
Изменено пользователем alpinemobile
